Thank for the info
This is very interesting and clears up a few issues relating to the SureFire Lamp Modules.
I was always under the impression that the best gas was Xenon. I knew that Halogen was a group of non-metallic elements (F, Cl, Br, I & At).
I knew that Halogen was added to Xenon to increase efficiency and reduce Tungsten deposits discolouring the inside of the bulb.
Halogen/Xenon was better for high temperature super-bright bulbs still giving a white light (due to the Xenon?)
Because the Halogen cycle requires high temperatures, the standard SureFire Lamp Modules (P60, N2 etc) can not use it, so high pressure Xenon is used.
Now I understand.
Does the Scorpion use High pressure or doesn't it really matter?
