Hi all,
I got a bit of a delima. Pulled out the little mini mag (moded with a 3led nite ize type module and a push button switch) i keep in the glove 2 find that i wasn't working. I simply thought that the battery was bone dry because it had probably left in the on position. I open up the little thing and found like a half a cm work of calcium from the battery, baked on in the barrel and no way to get the batts out. The first batt was loose because i heard it rattling and i firstly pored boiling hot water ( as if you get calcium bulid up on you car engine, this is what mechanics recommended) and nothing. So i soaked it a top of boiling water till it cooled and chisselled the calcium off but still no cigar. So now have a mini barrel, with 2 batteries, the end one baked on with calcuim deposits and i cant use the dammed thing! Does anyone have any bright idea to save the light or if not, prevent this from happening again? Thanks all
