Hi All
This tube is made by DSpeck, and instead of using SF tailcap like his usual UBH, this tube has its own tailcap, utilizing kroll tailcap.
The kroll is recessed and is modified to be two stage (by Led Zeppellin)
The arc LS head is first rev style, that was stripped and reanodized. Also, the whole bezel is loctite-ed together so it would be very hard to try to separate them.
It is currently housing RX1H Lux I, cut down SO17XA reflector, and arc stock plastic lens. the construction of the LE is a bit rough but it works. In other words, the whole set is a simple light that works.
Anyway, the body comes with adapter and spacer, so you can use 2 CR123, 1 CR123, 1 AA, 1 18650 or 1 17670 (might rattle) inside the body.
pic below
So this is what you will get:
1. Custom 18650 pack that let you use multiple cell options, and can fit to either arc LS series or E series head (if you have the arc to E adapter)
2. two stage tailcap (off-low-high), resistance on low is about 4~5 ohms.
3. Arc LS head first rev, stripped and reanodized, and loctited together. Try to separate at your own risk (there is a scratch in the top bezel to prove it).
the head houses RX1H lux I with SO17XA, plastic lens and DD. (it was still on its star)
My asking price: ($old) shipped in the USA. Out of country, pay actual shipping
I accept PP cash or CC (add 4%)
I am also looking for full or partial trade with the following item:
* Cree (preferably bare, WD color, P4 and up bin)
* Maglite 2D, does not have to be new. any color is fine
* Cree/Lux heatsink for Mag D sizes
* E series parts
* miscellaneous luxeons
* other stuff you might think of (pm me for offers)
Thanks for looking
pic below
* E series parts
Thanks for looking
