Had to do this one for a friend in the UK...
Original light had a LuxI behind an NX05 optic.
This light was a SCREAMER (back in 2001, hehehe)
So anyway, after boiling it in water, in a bag,
I finaly manages to remove the bezel.
I only did an emitter-swap and replaced the optic for
a 20mm SSC-optimized reflector.
The Emitter used was the Seoul USW0H from PhotonFanatic.
Pics showing both stippled and smooth reflectors.
The stippled-reflector has less throw, while the smooth
reflector has more throw... (well DUH !)
The bezel does Not screw down all the way, it can still
have a full turn. I was afraid of sanding down a plastic
reflector, but I might get to do it in the future.
The result is a stunning emitter collaminating it's light
by a 20mm reflector.
The circuit was not changed, so it can still run from
the same amount of cells as used to, and be brighter and
more efficient, while producing less heat also...
Check out my KL4 & Cree mod also here:
https://www.candlepowerforums.com/threads/162146
Questions, comments and suggestions more then welcome !
(PLEASEEEE, NO PM ! e-mail to george (at) bombelman.com Subject: CPF-CPF-CPF-CPF)
Cheers !!!
You gotta love that VG-FB1 body !
Cheers !!!
