Hello,
I just received my first Arc LS. Its a second. The bezel is first rate and so is the 123 cap, but the finish on the main housing connected to the bezel is pretty worn. Having said that, Its fairly white and has good output.
Regarding the 123 battery compartment; mine takes 2 1/2 turns from on to when the cap falls off. Also, I have ran surefire, toshiba, and sanyo batteries with no problems. I read other who have had problems in these areas. It has the green pcb and rubber washer and I suspect its the 400ma hybrid. I paid $49.95 from Arc.
My questions to you pros out there is;
Did I get lucky and get the better 123 battery compartment availible for the older LS?
Would you guys return it because of the finish on the main housing? Its worn in many spots to the metal but the light functions perfectly.
Thanks,
Thanks,
