anyone tried using a SF FM-65 filter on their Lumapower M1 ?
boosterboy
California
I was looking at the Surefire filters that are meant for the SF U2 and the SF M2, and I noticed that these filters fits 1.47" bezels.
The Lumapower M1 has a 36mm bezel which is
[size=+1]1.41732283 inches.[/size]
Now the SF filter has a locking cam that helps hold the filter in place once it's slipped onto the bezel. This locking cam probably provides so slack in tolerance.
FM-64 is a diffuser
FM-65 is a red filter
FM-66 is a blue filter
Any ideas?
If this works, this is a major advantage for Lumapower.
TigerhawkT3
CA, 94087
The FM65 should fit on the M1, as its diameter is just .06" more than the bezel's. If anything, it'll be a tiny bit loose, but that's easier to fix than an overly snug fit. If it's not solid enough, you could use some folded Scotch tape as a spacer. I really like SF Beamshapers, as they make a smooth, floody beam that can light up an entire room.
