IndecisiveFlashaholic
- Joined
- Apr 5, 2007
- Messages
- 98
I cant decide between the two. I have heard excellent things about both. Any advice?
What are the intended applications. If its specific applications it is easier to recommend to you.IndecisiveFlashaholic said:I cant decide between the two. I have heard excellent things about both. Any advice?
If not both SureFires, then go with the SureFire.A2. Just my thoughts on it, that's all.IndescisiveFlashaholic said:. . .mostly used on camping trips. Walking about the trails, card games, reading etc...
I would go for the A2 first since there is no low output from the L4 and 100 lumens to read it way too much light.IndecisiveFlashaholic said:It will be mostly used on camping trips. Walking about the trails, card games, reading etc...
If that's the case, the A2 is more versatile. Even if you equipped the L4 with a two-stage switch, the A2 comes ahead as utility light.IndecisiveFlashaholic said:It will be mostly used on camping trips. Walking about the trails, card games, reading etc...
luigi said:For this kind of usage I recommend the A2 with white LEDs.
The LEDs will give you a broad soft beam for the tent, card games and reading with a very very long runtime.
The incandescent beam can be used to illuminate the trails when walking, you can even hike using the LEDs using the incand from time to time to spot things and check the trail.
Luigi
tussery said:I would go for the A2 first since there is no low output from the L4 and 100 lumens to read it way too much light.
well White for starters....but now since Bawko invented the Aviaitrix rings, it doesnt really matter what color you buy first as you can change them out for other colors as necessaryIndecisiveFlashaholic said:What color stock led's would anyone suggest? As a personal opinion...
