HDS Systems
Results 1 to 8 of 8
Thread: SF E1e Led drop-in, low power - long runtime
    Nov 2006
    Germany
    Default SF E1e Led drop-in, low power - long runtime
    Maybe it was posted before, I dont' know.
    You need a (defective) MNxx bulb, one RCR123 (3,6 V),
    a Super MJ-Led (uncut) and a 2-2,2 Ohm resistor.
    The led is driven at 80-160 mA.
    The output is a bit brighter than the Aviator A2 on low
    und much brighter than the ARC AAA-P.
    Runtime is 7-9 h.
    A nice drop-in for backup, when using the E1e with incands.
    *** Important: do not remove the wire from
    the bottom contact of the lamp assembly.
    This part is hard to solder ***
    E1e-drop-in, distance 2 Meter
    Surefire A2 (3 leds)
    Flashaholic* Blindasabat's Avatar
    Jan 2006
    Michigan
    Default Re: SF E1e Led drop-in, low power - long runtime
    Nice Job. Drop in mods rock. Nice backup to an incan too! Wish I had not thrown away a MN01 bulb I blew a few months ago. I remember wondering if I could use it, but thought "Noooo, I should just throw it away..." Bummer.
    Flashaholic* KDOG3's Avatar
    Aug 2004
    Sea Isle City, NJ
    I wonder how much brighter the Super MJs would be?
    FAILURE TO PLAN ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
    Nov 2006
    Germany
    I have used the Super MJ Led (4-die).
    Output is in the range of 10-12 lm.
    Jun 2006
    North of 43
    Energie, I keep finding your posts on mods for the SF E1e heads and they rock!
    I have some spare 5mm LED's and want to do this mod but the MJ-LED's sound great; 10-12 Lumens. Do you have any numbers on runtimes?
    Looking for: jhanko 'biohazard' V10R Ti clip, Luce de Notte (SS / Ti), SF Z2 (body, complete light, bored, unbored). Pls PM me with an offer.
    Aug 2004
    Sea Isle City, NJ
    What about the Nichia Jupiter leds or even the Rigels (which I can't find). The Jupiter supposedly puts out 51 lumens at 350mah. Might need to use a converter board though...
    Quote Originally Posted by KDOG3 View Post
    I have a few Rigels, if you want some.
    PM me more more info.
    Toshi
    Nice. Would this work when running 1*CR123 or 2*CR123 (primaries)? Would a different resistor be needed?
