joerky
Hi there!
As you know, the fenix should be able to stand on the tailcap:
But mine got a problem to stand on a flat surface - because the switch is not plan enough. The rubber thing ist too big.
So i decidet to mod the switch.
I unscewed the silver ring and here are the pieces of the tailcap:
You see 4 pieces and additional a piece i cutted from a bike tube. That piece fits on the rubber cap:
So it comes a little bit lower in the tailcap - and the Rubbercap is now low enough that the tailcap can stand on a flat surface:
Here it stands:
That was easy and it kepps the waterresistance - because the additional piece is also made of rubber.
Greetings from Germany
Joerky
Capable of standing up securely on a flat surface to serve as a candle
Here it stands:
Joerky
