A Purdue University engineer has developed a method that uses an aluminum alloy to extract hydrogen from water for running fuel cells or internal combustion engines, and the technique could be used to replace gasoline.~
Hydrogen is generated spontaneously when water is added to pellets of the alloy, which is made of aluminum and a metal called gallium. The researchers have shown how hydrogen is produced when water is added to a small tank containing the pellets. Hydrogen produced in such a system could be fed directly to an engine, such as those on lawn mowers.
"When water is added to the pellets, the aluminum in the solid alloy reacts because it has a strong attraction to the oxygen in the water," Woodall said.
This reaction splits the oxygen and hydrogen contained in water, releasing hydrogen in the process.
The gallium is critical to the process because it hinders the formation of a skin normally created on aluminum's surface after oxidation. This skin usually prevents oxygen from reacting with aluminum, acting as a barrier. Preventing the skin's formation allows the reaction to continue until all of the aluminum is used.
http://www.physorg.com/news98556080.html
