This was the first non reversable mod I have done to a Surefire, as well as the first time
to work on the business end of a light (only tailcaps and bodies until now).
Soldered a LED for the first time too!
KDOG3's post Any new LED mods for E1e? got me interested, and fellow members
Energie and Long John's great mods Surefire E1e with SSC-P4 made me think of a
simplified version.
No modification was done to the reflector.
Direct Drive, no regulation.
Read on to see the rather dissapointing results. Was great fun tho
Opening the bezel
You don't necessarily have to do this, but it makes removing any metal shavings
that get into the reflector easier.
Crude wooden clamps and a thin rubber band were used for a better grip.
Would be better to sandwich something between the wrench and bezel to avoid
scratching the HA.
No heating was necessary to loosen the thread locker on this particular unit.
YMMV.
Removing the jut and leveling it out
A lathe was used here, but a Dremel and some patience should get you similar results.
Widening the emitter hole
I was originally going to use a Cree XR-E and widened the hole with a 7mm drill bit.
This resulted in a lot of space between the SSC P4 emitter I later decided to use
Converting a MN01 LA into a pill
This is a burnt out MN01 in the original condition.
Step 1
Prying open the positive contact.
Snipping off the bulb leads, leaving a short length for resoldering.
Step 2
Sawing off the bulb and removing the epoxy.
Making the heatsink
A milling machine and lathe was used during this process (experimenting with some ideas ),
but all you need to have is a simple copper disk (diameter 19.10mm, thickness 2.6mm) with
2 drilled holes.
I had a chunk of 5mm thick copper, so milled a 20mm square down to 2.6mm and sawed it off.
This is a jig I made for securing the copper square to the lathe. Cap screws are M2.
With all the excitement, I forgot to take photos before the square was turned down
to a disk.
I have a feeling no one will understand, but this part was the most fun for me.
Step 3
Soldered new leads and drilled a hole in the stock plastic ring.
Step 4
As discussed elsewhere, the P4 emitter slug has a positive contact.
A bit of extra Arctic Alumina Epoxy and gentle pressure was used to secure it to the heatsink.
The gap as mentioned before
Beamshots
These were shot from about 20 inches from the wall.
I have a feeling I am losing a lot of photons somewhere. The BIG donut hole and
complete lack of a hotspot makes it look really dim.
But the flood is amazing
I'm thinking of getting a McR 20 reflector and working some more on the bezel with the lathe.
Any suggestions to improve it are welcome.
nekomane
simplified version.
Opening the bezel
scratching the HA.
YMMV.
Step 1
Step 2
Making the heatsink
2 drilled holes.
to a disk.
Step 3
Step 4
Beamshots
nekomane
