Flash007
Description and specs taken from www.wolf-eyes.com :
Digital Cree P4 HO 3.7v-6.0v D26 LED lamp assembly
- Digital circuit function:
The preset initial status of the lamp is maximum brightness(100% brightness). Press the switch at the tail cap allows alternation of brightness / functions according to the sequence of " maximun brightness (100% brightness) -> 20% brightness -> lowest brightness(2% brightness) ->strobe " ; and the whole sequence recurs in cycles.
After switched off the flashlight for 2 seconds, the default settings resume, and the lamp will enter full brightness when being switched on again.
- Specification:
-Brightness:170 lumens(maximum stage)
-runtime:
with 1 X LRB 168A Rechargeable batteries:
full brightness stage: 110 minutes with regulated output ;
30 minutes with unregulated output.
20% brightness stage: more than 550 minutes
2% brightness stage: more than 5500 minutes
blinking stage: 220 minutes with regulated output;
more than 30 minutes with unregulated output
with 2 X CR 123A Rechargeable batteries:
full brightness stage: 80 minutes with regulated output ;
4 hours with unregulated output.
20% brightness stage: the runtime is more than 400 minutes
2% brightness stage: the runtime is more than 4000 minutes
blinking stage: 160 minutes with regulated output;
about 8 hours with unregulated output
-runtime:
Specs for 130 lumens is also available.
EXCELLENT NEWS ! :thumbsup: :twothumbs :naughty: :thumbsup:
