mrmike
It's made by Brinkmann; a Mag clone that was much cheaper than official Mag at the time I bought it (and just as well made if not better). It takes 5-D cells. I think it's about 20-25 years old and in terrific condition. The reflector is slight scratched. (I foolishly must have tried to clean it some time ago).
I've wanted to do something with it. I tried a TLE-6EX but it doesn't fit, as the diameter of the (Brinkmann) bulb post is slightly larger than a Maglite post (and the female piece of the Terralux is sized for a Mag post). At $25 for the emitter I didn't want to strip the threads to try to force it on.
The Terralux MiniStar-1 I have in it now works just fine as it's a standard PR Flange, but the output is kind of lame for the size of the light (and my MiniMag/TLE-5EX puts it to shame).
Why try to make an ROP out of it? I noticed in some threads there are issues with the plastic post in the Mags melting, and look at this:
It's (almost) entirely metal. Remove the bulb, and there's a piece of plastic in the bottom of the post isolating the positive contact:
What do you guys think? I'm a newb here and have only done some drop in stuff, so I don't know if I can pull this off. I replaced the plastic lens with a 50mm optical lens (the 52mm Maglite lenses don't fit) that I got from a science supply outfit (I think it's a lens for a cheap telescope... it works just fine). A huge issue is the (plastic) reflector is also slightly smaller than a Mag, so I can't use the aluminum reflectors sold by some of the CPF'ers.
Any ideas or am I wasting my time?
