Thanks Steve. Therefore, presuming O-rings contain no sulphur, there's not much reason, then, for silver sulphide to form upon any silver-anything that might be found inside flashlights.Partial quote:
...I note in some of the design data that pure silver's environmental resistance is considered very good because it slowly forms a relatively innocuous conductive silver oxide. It more readily forms silver sulfide which is non-conductive but very weak and easily displaced by wiping action or high contact force, or "punched-thru" by voltage.
Do switches often bear silver plating?
Now for the biggie-question: What's with this
tailcap spring in my new Fenix P2D-ce?
It's a relatively fine bronze (?) wire, bearing what appears to be thin gold plate.
I would think that
pure silver plating would be a lot better than a few mere microns of gold, atop a substrate of nickel plate that in turn is atop the base metal wire.
Why,
if it were a sufficiently-heavy plating of silver on that spring, the
silver skin could become the prime path for the current
(bronze isn't so suave a conductor, and brass is positively bad).
Thanks in part to you, Steve, I now feel bold enough to state flat-out: Gold plate is liable to be found in places where it does not rightly belong. Tailcap springs?
Can you do some sort of evaluation? I don't know,
I guess the Fenix P2D spring is what, a few inches long,
and bears some kind of minor current, eh?
I have zero skills to determine just-what-and-how-much;
I can only work on broad concepts and intuitive logic.
Good engineers work from basic facts, and so get the job done right.
And, engineers who have both your
intuitive genius
(I've seen your product design skills), and your mathematical skills;
such men are the golden....no!...the
SILVER Sons of the Scientific Arts.
In desire of more data, thanks Steve,
Reid
