whc
Just visited the Dereelight.com and found a new flashlight commin soon, with Cree P4 LED, and same regulation as previous CL-1H, but with much more output, see here: http://www.dereelight.com/dr-dbs.htm
From the webside:
DBS-> Dream Beam shot
Main features:
LED: Using a Cree P4 or Q2 LED, Over 50000h lifetime.
Circuit: Full-regulated circuit, wide input range, Can feed with 1x18650, 2xCR123A or 2x16340 battery
Circuit Protection: reverse polarity protection built in the circuit
Output: Two stage output by turnning the body shift.
LED current: 240ma on Low, 750ma on High
Reflector: Aluminium smooth reflector, OP reflector for optional.
Dimensions: 165mm(Length)x 45mm(Head)x 25mm(housing)
Material: Constructed of aircraft grade aluminum
Surface: Type III hard anodized finish, highly durable
Waterproof: Double O-ring design, better waterproof.
Weight: 180-gram weight
Switch: Tactical switch by push the rubber cap of the tailcap
Clip: Removable clip ring.
Glass: Toughened ultra clear glass lens with AR coating
Package: Giftbox
Accessories: Spare rubbercap, Extra O-ring
It's our New Light, same circuit with CL1H, but double brightness...will on sall midle of June.
From the webside:
