You've come to the wrong place!! There are no high powered lights here, less in the 123 thing youre mentioning. You wont get any help, and the people here have no idea what you talking about.. i suggest you leave right now before its too late... O if you ever find out what an Orb Raw NS Cree is , I suggest you dont buy that either...the thing is no brighter than a candle and wont serve you any purpose, sincerely I dont even know what that is... One word of advice HOLD ON TO YOUR WALLET...
+1 on the Fenix P2D-CE. Lots of brightness levels in a small package.
The soon to come Fenix P1 Cree might be what you want if you want a tiny single cell single setting bright light. http://fenix-store.com coupon code CPF8
If you want maximum throw, the lumapower D-Mini. If you want more throw than that (D-Mini is up there with full-sized lights for throw) try fitting it with a 30x15mm aspheric lens. I'm not positive that it will work (if someone has actually done it, I'd like to hear about it), however, I have used this lens in a Lumapower M1 successfully, and the D-Mini does have the same head diameter. here are some beamshots of what the M1 looks like with that lens.
For the most possible light in the smallest possible package (read: 130 lumen keychain light) try the Fenix L0D-CE with 10440 LiIon battery.
For 1xCR123, I'll say Fenix P2D-CE. It uses the same interface as the L1D CE which is very elegant, and has multiple current-regulated output levels. Twist to go straight from low to turbo, tap to go from low->med->high->SOS, tap to go from turbo->strobe
You need Orb Raw Ns upgraded with a Seoul emitter. Trust me on this.
whats the diff between the P1D and the P2D?
If you want to go really tiny (just barely larger than a AAA cell) and bright, ModaMag's Draco with Cree LED is great. But it's going to cost you!
I also recommend the P2CDE 135 Lumens. 55$ (Best lumen for $$$)
P1DCE 135 lumens 67$
P1CE 90 lumens 40$
And don't forget the coupons.
I just received some cheapo crees flashlights and when you light the Fenix you SEE a big difference.
