I bought this reflector (http://www.dealextreme.com/details.dx/sku.3257) and have used it together with a SSC P4. The base of the reflector cone itself sits on top of the black surround on the led.
My question is, is this the optimal position for the SSC? Or should it protrude further into the reflector cone (remembering this is a cree reflector)??
Anyone modded one of these? did you have to open up the hole for the led to fit into the reflector? and if you did how did you overcome the reflector contacting the -ve and +ve on the led? Was it necessary to sand the base of the reflector down a bit?
I've remove the threads as I did not need the slug that screws into the reflector.
