Drakonchik
Maybe Mag2AAs and 1W Luxeon LEDs are tough, but the collimator lenses can break real easy.
I found this out repeatedly with my MagAAs fitted with the InReTech 1W Luxeon Star (wht.) adapters.
I've shattered five collimators in these Mags in the past few months. The collimators all arrived from InReTech at different times during this period, presumably from different batches.
What happens is: the edge of the collimators crack and/or shatter when I push the Mag into the Flashlight Friend accessory (that plastic tube with the adjustable legs.)
And I know why. When you tighten down the head of the Mag, the bezel pushes on the edge of the collimator, which presses on the LED adapter, which presses on the Mag bulb platform, which presses on the switch, which turns off the flashlight. If you continue turning the head, the platform bottoms out against the shaft of the tube. Unfortunately, the threads of the head and the tube do not bottom out at or before that point. So now if you continue to forcefully twist the head, you are as a result compressing the whole assembly. The pressure on the edge of the collimator builds, and it shatters.
Why would some knucklehead twist the head past the beaking point, you ask? How about if you want to screw the head down tight so it doesn't turn on in your pack? (Yes, I have Kroll switches, but keep reading.) How about if the Flashlight Friend is a little tight, like outside in the cold for example, and you have to twist and push hard on the Mag? How about you hand the flashlight to your pal, a 600lb gorilla, who doesn't know any better? /ubbthreads/images/graemlins/shocked.gif How about you just like twisting hard on your flashlight, huh? /ubbthreads/images/graemlins/mad.gif
Fortunately, I think I've figured out a modification to the collimator and the platform that will solve the problem. /ubbthreads/images/graemlins/smile.gif What you do is this: grind about 3mm off the conical tip of the collimator; grind just over 1mm off the top of the platform; and grind out a couple of tiny slots that will allow the LED leads enough space to feed into the platform. I've done the aforementioned grinding, and I'm just waiting for a replacement collimator to test out the fix. Will post results.
