Cydonia
Parts and tools:
A poor man's HA III finish? :laughing:
Step 1: Bike inner tube measured against the Maglite. Cut to length with scissors adding 1" or more than needed.
Step 2: Wash piece of tube in hot water with detergent. Turn tube inside out (can be difficult!) and wash off the powdery dust and haze.
Step 3: Dry tube inside with hair dryer. Place tube and Maglite on table and heat both at same time with hair dryer on high heat for several minutes. The hair dryer heat is the only way the inner tube will stretch enough to fit. Work fast before it cools!
Step 4: Stretch tube and get it down over the Maglite. Can be really difficult if not done right. If at first you don't succeed try try again
Step 5: Measure and cut the second piece of tube for the Maglite head. Wash in hot water, turn inside out, dry, heat, stretch, then fight it over the Maglite reflector. Leave a small ridge over the bezel rim. In the pictures 2 lights have extra layers of tube over the bezel edge.
Step 6: Adjust alignment and trim the join between Maglite tube and reflector head with a razor.
[4C and 3D don't have the inner tube inside out, so that's why there are seams and lines visible. The 3D has the series of inner tube join seams positioned over the switch area to aid grip.]
- $5 worth of new bicycle inner tubes - (one size fits all type) from Wal Mart
- sharp blade
- scissors
- hair dryer
