So I just tried swapping out the momentary switch with the reverse clickie using the guide at batteryjunction.com (http://lib.store.yahoo.net/lib/theshorelinemarket/Switching.pdf). Problem is the clickie switch gets jammed after a couple of turns into the tailcap.
That's as far as I can get it before it gets stuck.
Any ideas on what can be done?
__________________________________________________________________________
Update - Threads and o-rings cleaned and lubed!
This is the first light I got that has something that isn't clear on the threads...
Lumapower M1
Any idea what that stuff is? I generally use Nyogel 760G on all the threads of my lights but not sure if I can on this one.
Lumapower M1
