jlomein
I am curious if the stock Surefire E1L luxeon can be used as a candle continuously?
I've never owned one, but I own a modified E1L that has a McR20 reflector and Seoul LED. I am powering it with an AW protected RCR123.
I tried using it as a candle, leaning against a book to make it stand. After about 20 minutes the light started to flicker and then shut off. When I touched it, it felt very hot. After letting it cool for about 10 minutes, I turned it back on and it worked at full brightness. I took out the RCR123 cell and it tested at 3.87v, so it was not dead.
I thought Seoul LEDs generate less heat than Luxeon? What caused my light to turn off? Do stock E1L's do the same?
