Christexan
- Joined
- Sep 29, 2006
- Messages
- 224
Okay, I have put some pictures up that have been a "long time coming" on my website:
http://christexan.com/Biking/bikelights/LensComparisons/index.html
It's not much, but I've been waiting for awhile for someone (anyone) to actually compare the Polymer Optics brand optics for the Cree XR-Es to any other optics. Nothing has appeared in the past few months (well, I started looking in Jan/Feb timeframe). If anyone wants to link to those photos and put them "inline" here, you are welcome to, I didn't feel like messing with it, it's a single webpage that gets the point across quickly.
Okay, my conclusions in a nutshell, the 6-degree seems great (as does everyone's 6-degree), however the 25-degree Polymer Optics is trounced by both the Ledil and the Fraen 25-degree models. It is full of artifacts (no surprise, it's not diffused), but more importantly, without diffusion, it appears less bright than the diffused Ledils and Fraens! I could be wrong, I don't have a lightbox, but to my eye, and in the photos, it just doesn't compare, maybe it's the dark artifacts throwing me off, but it appears there is a lot of light being lost in the geometry (leading to the dark "square" where you would expect a solid wash of light just off center). I tested 3 different ones, so it's not a bad lens (I had to reseat one in the "holder" they are just a press fit, so they require some sort of cover to secure them besides the holder, I emailed Polymer Optics twice now (different issues), the last time regarding whether the flats could be used to apply silicon to secure the lens in place without substantial light loss <edit> and have received a response on the last issue, that there would be some light loss on the machined edges, but essentially, they aren't the best reflective surfaces to begin with due to their machining process (their words), so it wouldn't be a large amount.
Anyhow, they are tiny, the hexagonal pattern makes great packing density (they match the "MR-11 triple lens" format used by Khatod exactly, but without the extra "ring" of material to fill out the MR-11 circle), 3 fit in roughly the same area as a Ledil lens, but the 25-degree is losing light somewhere. The 6-degree is great, appears about the same as a Carclo or Ledil 6-degree optic (basically a concentrated image of the LED die itself, only bigger).
Hope that helps someone out there considering these lenses, again it's not a "1-off" test, I tested several samples and verified proper seating etc, and the 25-degrees just don't compare to others out there.
For what it's worth, I've tested optics from Khatod, Fraen, Ledil, Carclo, and Polymer Optics so far, the Fraens are nice but have a slight "6-point star" pattern in the 25-degree model, it's not distracting though in usage, more interesting as a curiousity than anything when "white wall hunting".
