Just received one for trade, cannot get the 123 body to work. Everything seems clean and tight but this body will not function. Was informed by trader, works with the AA bodies. Suggestions?
If the ends of the tubes are clean of lube, etc., I'd first try backing the head off ever-so-slightly. That has worked on some similar form-factors. Also, it could be that the tube isn't even contacting the ring in the head (or tail). Try turning the spanner ring or module in towards the body.
