I'm thinking of making a geothermal cooling system for one room in my house. The basic concept is: air blows into underground PVC tube and gets cooled while it is in there. Cooled air gets blown back into room.
So I experimented and put a vertical 3 foot piece of 3/4 inch pvc in the ground. I came back 4 hours later and measured the temperature at the bottom of the vertical PVC at 64F. Great! That's more cool than the current 80F.
I'm thinking of making a circuit of 1 or 2 inch PVC, about 26 foot length, to circulate air. The air from the room will be blown into the pipe by a blower, and exit into the same room, hopefully cooler than it went in. The air will go down into the ground 3 feet, travel out 10 feet, travel back 10 feet, then back up 3 feet into the room. Blower will be located inside the house. Ok, that makes 26 feet the air has to travel.
So now I'm thinking I need a blower to blow this air around. And I'm thinking all this air has weight. How powerful a blower to I need for 20 feet of 1 inch PVC? I was looking at computer blowers (not fans) and was thinking they are not made to blow that much air around.
Do I measure the power of a blower in cubic feet per minute? Or pounds per square inch?
I could use an 110V AC or 12V DC blower. I have a 12V DC adapter I could plug into a wall.
Thanks!
Thanks!
