I'm looking for an LED drop-in for my 2AA PT headlamp and just placed an order for this module through the Sandwich Shoppe. After reading about this module I think I may have just made a serious mistake. It looks like this module has less output and actually uses more power than the previous SMJLED. It appears it also loses 95% of its output in about 250hrs of use.
Is this true? Has this issue been cleared up with design improvements? Is this module even worth bothering with? It said on the site that this is the newest generation of SMJLED2, hinting that it is a modification of the original. I'm confused. All my PT Quest needs in order to be the perfect headlamp is a decent LED module. Its the only headlamp that I know of that uses AA batteries but doesn't require a rear battery pack. What do you think about my purchase?
