SureFire M3
Three SF123As
MN10 125Lu/60min
MN11 225Lu/20min
SureFire M3T
Three SF123As
MN15 125Lu/60min
MN16 225Lu/20min
N2 105Lu/60min
SureFire M4
Four SF123As
MN60 225Lu/60min
MN61 350Lu/20min
N62 500Lu/12min
SureFire M6
Six SF123As
MN20 250Lu/60min
MN21 500Lu/20min
There is only one Shock Isolated TurboHead - The "Millennium" TurboHead.
It is used on the M3T, M4 & M6, M900AB, M500AB, M500B, MU97 & MU98. It is the TurboHead of the KT4 TurboHead Kit.
What can one do with the M4 if one has some parts kicking about?
1) Replace one SF123A with a Z20 Battery Spacer.
Use the three SF123As in the M4 body to run the MN15, MN16 or N2 Lamp Assemblies.
2) Replace one SF123A with a Z20 Battery Spacer -
Use the "Z46" Shock Isolated Bezel (from the M3 for example) and the three SF123As in the M4 body to power the MN10 or MN11 Lamp Assembly.
3) Replace two SF123As with Z20 Battery Spacers -
Power the N1 Lamp using two SF123As in the M4 body.
I do not know why you would want to do any of these three things. I would do them if I really needed light and I didn't have any M4 Lamps or enough SF123As available.
I hope this helps.
If you would like some photos, please email me:
[email protected]
Respectfully,
Al
