Hmmmm...... looks like the Buck Rogers Laser Master Series 1.
Originally posted by RebelXTNC:
It's a Black & Decker version of a M@glite. It uses the 3.6v rechargeable VersaPak batteries. The really unusual thing is the construction. The body is made up of two separate pieces, the tube and the switch housing. The head is a separate piece but fixed onto the body. The bezel ring turns for spot to flood. The tail cap encloses the end of the battery pack, no spring needed since both contacts are on the other end of the pack.
A heavy duty light, but just average incan performance since the bulb voltage has to be fairly high and the batteries have usually self-discharged a bit when you need the light.
You're sure right about it being built heavy duty...just check out that tailcap!
I have most of the VersaPak tools...they're fine for fairly light duty "around-the-house" type work, but I wouldn't push them much past that. The exception of course, being the aluminum flashlight, which is built like a tank!
Might be a candidate for a cool mod...maybe someone will figure a way to adapt a VersaPak battery pack to hold 3 X CR123s!
PS. Their VersaPak powered compact flourescent lantern is pretty cool too.
