Tony graciously has permitted me to post a PM here to update the thread so that should anyone else come along they might get their answer here. Sorry for the delay, been traveling ALOT.
No problem. I think that I was thinking too narrowly with products that would work for you. I do not work with different varieties of microscopes often like you would, so I only pictured in my mind just a few that I have seen and used before for classes.
I thought that you needed the tightest little spot possible, and I just had that one optic in mind. A reflector would work nearly as well. If you would shine a flashlight using an high flux LED and a reflector on a wall at a close distance, there may be a good chance you will get a projected donut shape in the beam. However, I was thinking that if you would de-focus the emitter in the reflector, you can focus it where you can get a tight, solid spot at close distances.
For the most part, those two lamp modules should work for you. If you would happen to get a "donut" beam, you could move the module so it is slightly off center so the dim donut hole is not projected directly beneath your slides. It seems like it would be easy to pop off the springs (if needed) and solder on your own wires directly onto the contacts on the back of the driver board.
So I just wanted to check. Are these modules to be free standing (fixed) with the battery pack and/or converter sitting beside it secured, or do you want to fit this module in a flashlight to rest underneath the microscope?
What would the reason be that you would use batteries for this light? Is it so it can be removable to be used for other things? Lithium batteries can chargers seem expensive, especially if you do not plan on making your microscope mobile. In that case, it may save you the trouble to use a cheap wall adapter. Now, if you have any intentions to move the microscope for on-the-scene field work, then the battery idea would be awesome. Imagine firing that puppy up next to someone else's microscope when they have the cheesy battery-powered screw in light bulb to illuminate things. That would catch some attention for sure. I did not save the picture that you posted of your microscope, and I just forgot how things are set up and how much room you have.
I wanted to point out that if you get either module, it will have its own converter installed in the rear under the springs. I think they are buck circuits to be used with one or two li-ion cells (which would work I guess if you wanted to go the battery route), but you would have to check the descriptions and reviews/comments. This driver may possibly not work for the fixed lighting, depending on the minimum and maximum V-in of the driver board and the supply voltage of your wall adapter. It may work however, seeing that you plan on using a 5V adapter. A cell phone charger may work, but you may not get the 1000mA that you want.
You know, if you want, you can even get just the reflector that is the same or similar as to what is used in those modules. This way, you can specify the emitter (if you have much of a choice) and the driver. If you want to make this use a plug-in wall adapter, you do not have to worry about taking out the included driver to use the AMC7135 1050mA regulated driver instead, simply because you can choose which to buy from the start. Here:
http://www.dealextreme.com/details.dx/sku.3257
Now, according to the reviews, I remember that that above bare reflector does not work with the full size Cree star or circle shaped board (16mm or 19mm), but instead, any board that is under 15mm will fit, such as the following 14mm Cree XR-E P4 circle, for example:
http://www.dealextreme.com/details.dx/sku.3475
You can get the larger star with the newer Q5 emitter and trim it down, but that sounds like a pain. I guess you would only have to trim off the protruding hex-board material to allow it to fit. The best thing about getting the reflector and emitter separate (my main reason for bringing it up) is that you can purposely defocus it by adding a cardboard disk on top of the star to raise up the reflector, or by making the LED sit up higher into the reflector. This way, the spot would be tight and bright and better focused. If you play with a mini-magLED, you can get a super small spot on a close by wall or piece of paper by de-focusing the LED a bit. I forget which way you have to turn the head. The same should work for the Cree and the orange-peel reflector. In addition, it is cheaper to build your own (and not necessarily any more difficult since you have to solder things anyways). The aluminum relfector set costs only $2.77 and the Cree XR-E P4 emitter fixed on the 14mm board costs $6.13. This is $8.90 total so far without the cost of the driver, of course.
I just wanted to share some other ideas. I think that you can go any route by using the reflectors from DX and be very pleased with the super-bright results. I understand time and money has to be an issue some, so you do not want to go through too much hassle just to light the specimen slides with today's LED technology. I suppose the cheap $3 10W xenon bulb and reflector module from DX would work easier, too, but there may be an issue of cooking your specimens (if organic). That would not be good at all! :mecry:
Anyway, keep me posted on what you come up with. It is exciting to see LEDs being used for such application more often. It is sort of refreshing! Good luck!
-Tony
P.S. - Feel free to post this on your thread if you think it would be of help to other people. I never thought of it before.
Quote:
Originally Posted by
purduephotog
I'd like to thank you and ask a pair of questions as a followup for my microscope stage illumination.
1) I saw this linked over at FatWallet.com- it would appear to meet most of my requirements:
http://www.dealextreme.com/details.dx/sku.1447
or
http://www.dealextreme.com/details.dx/sku.1343
And then I'd need to power it, so:
http://www.dealextreme.com/details.dx/sku.975
And Charge it
http://www.dealextreme.com/details.dx/sku.1251
2) If that isn't appropriate, there's also the individual parts (I could scrap an AC adapter that produces 5 volts) and purchase a 10 pack of regulators such as this:
http://www.dealextreme.com/details.dx/sku.1885
Thanks again for your help and I can post this on the thread if you'd like-
