The 2xAAA Swiss Army "version" of the Inova radiant is significantly better than the 2xAAA standard plastic Inova radiant in terms of brightness and build quality. The switching mechanism is better as well since the Swiss Army logo gizmo allows using the twistie almost like a slide switch. The brightness is somewhere between the regular radiant and the Nuwai/RiverRock, however you don't have that annoying extreme blue tint. Rather, the blue tint is typical Nichia 5mm blue similar to the regular radiant or the Gen 2 Inova X1 -- probably same Nichia LED. It is also brighter than the Gen 2 Inova X1 that I have, but this may be due to statistical variation. They are very close.
My guess is the 2xAAA Bolt version would match the characteristics of the Swiss Army as far as the LED goes, so maybe that's another avenue if readily available in your area.
EDIT: Based on another thread, my reference was to an earlier generation 2xAAA Swiss Army/Victorinox, not the latest. I didn't realize that this model had been updated.
