- Does it have a real HA3 finish ?
- Does it have SSC P4 U bin ?
- Is the workmanship of this model good ?
- Is it a good light for the money ?
- Does it look like the original......?
- Does it meets your expectations ?
I just received mine. I ordered it for the $25 price, I can't remember if it was advertised at that time to be Type II anodize or hard anodize. I see that the $35 one for sale now is listed as hard anodize, and a Type II version can be ordered seperately. Ok here goes:
- Finish on mine is type II, but is very nice. Seems pretty tough for type II.
- Not sure on the bin, as there's no way to tell. Mine seems as bright as a U bin. The light drives the emitter around 700 mA on high, and this one seems as bright as other P4 U bins I have that are driven at that level...which is bright. Flawless beam, perfect for indoor/close range use, but also has very good throw. Appears to be a SWO tint, which is classified as pure white.
- Workmanship is excellent
- EXCELLENT light for the money
- It is original, just not the current Version 4 that Waion sells. Waion talks about this particular version somewhere else on the forum.
It only has the two buttons as shown, press the top one to increase brightness, press the lower one to decrease brightness. Low is lower than any of the Fenix lights, but not as low as a LiteFlux LF2 or HDS. Pretty low, though. It doesn't have the strobe or SOS modes.
The tail switch is a forward (tactical style) clickly that is SUPER smooth and almost silent. The amount of force required for momentary is almost too little. I'd be afraid that just the pressure from being in a holster would activate it. The tailcap can be locked out by unscrewing only 1/8 turn or less.
It has more than 16 levels. I've counted about 22 visually (the high levels start to blend together), but it does take 32 presses to get to low from high. You don't have to press separately of course, I was just trying to count the levels. It takes about 2.5 seconds to sweep from low to high, and 2.5 to go back. You can stop anywhere in between. One cool thing is that when turned off, the light will stay at that level when turned back on. It's neat to have it on low, then turn if off. Then you can use the switch for momentary low...very useful for navigating in the house during the middle of the night.
All in all, I LOVE this light! I'd buy it again even at $35.
