cosine
- Joined
- Dec 19, 2005
- Messages
- 159
I'm seeing this term quite a bit, and am a bit confused as to what it means. (That said, I'm still a bit befuddled as to what you guys consider a "regular" clicky. Guess it shows that I have no clicky lights.)
Is a regular clicky the type of switch where the light comes on as soon as you slightly depress the switch, and you then can either release the switch to turn off the light or continue depressing the switch until the light stays on without the switch being depressed?
Is a reverse clicky a switch where the light does not come on until you depress the switch forward and it reaches the end of it's travel and clicks?
I guess the idea I'm thinking of is that a with a reverse clicky the light doesn't turn on until the switch clicks, while with a regular clicky the light turns on momentarily as soon as you depress the switch and then the light goes into constant on mode when the switch clicks.
Am I making myself clear?
