smcharchan
- Joined
- May 1, 2007
- Messages
- 44
Folks,
Your help would be much appreciated. I've been tinkering with basic ROP hotwires for some time, but AW's multiple level driver has arrived and I would appreciate your advice. For some reason I find the world of bi-pin bulbs intimidating. My CPF search has revealed a lot of experimentation, but not a lot of summary/comparrisons. Luxluthor's comparison is excellent, but doesn't fit the 2xC form factor that I am shooting for.
Would someone please recommend which bulb and reflectors I should use to get maximum performance out of my 2xC Mag with 2 of AW's protected Li-Ions? Is one of the 5761 or 1111 bulbs mentioned by AW the best? If so, what are the differences between them? Is there another bulb that will work better with the lower levels of the driver (i.e. not get too yellow)?
Also, is there a ready-made tailcap that contains a charging port? I don't want to have to mess with magnets, and my new WE Shark (sweet) has turned me on to the ability to charge the light without removing the batteries. What voltage plug-in charger would be appropriate for 2 cells?
Finally, please recommend an appropriate reflector. I prefer a LOP reflector for my ROP hotwires because I really notice discrepancies in the beam when the lights get this bright.
Thank you in advance for your help. -SMC
