Arc 4+ Switch?
Status
Not open for further replies.
Greta
Arizona
Originally posted by nmiller on 8-05-07 HERE:
Whats the deal with the arc 4+ switch? Can it be repaired? What goes wrong with it?
Thanks,
Nick
Greta
Arizona
Copied replies:
karlthev08-05-2007 12:10 PM
Re: Arc 4+ Switch?
Hmm, hot question I'd say. I'm no expert by any means but, the Arc 4 had a switch very sensitive to battery length as well as to shock. Initially the wrong battery length would create a bunch of difficulties later, wth some improvements, the switch did experience more relaibility however, the switch some say, lead to the demise of the Arc 4 and Arc itself. Clearly there were more issues than the switch but it did not help Peter Gransee. Can it be fixed? How's about it depends? I have several Arc 4s and performance varies from light to light--one is flawless and the light is a shelf queen. Another I just recently acquired, is about as fine a one as I've encountered. The switch is not one easily repaired I'm afraid. Let's see what soem other members have to say on this one.
Karl
nmiller08-05-2007 01:22 PMRe: Arc 4+ Switch?
Thanks Karl. Hopefully more will chime in. What happens if the switch does malfunction?
Nick
karlthev08-05-2007 01:27 PMRe: Arc 4+ Switch?
I didn't do a search and I forget who was working on these and sometimes successfully as I remember. I believe as well that Peter (Gransee) was "offering" $150 for each one returned that did not function properly. Try a search for Arc4+ and see what comes up. There is a vast storehouse of information on this.
Karl
nmiller08-05-2007 01:47 PMRe: Arc 4+ Switch?
Karl,
I've been looking. You are right. There is a lot of info out there and so far I'm not too thrilled about picking one of these up.
Nick
karlthev08-05-2007 01:49 PMRe: Arc 4+ Switch?
Do a search for this one. It gives quite a bit of information.
"Who still uses their ARC4+?"
Karl
PM to you.
Karl
THE_dAY08-05-2007 02:05 PMRe: Arc 4+ Switch?
here are 2 links by cy
tailcapmod
service for Arc4 switch
karlthev08-05-2007 02:30 PMRe: Arc 4+ Switch?
Those are good hyperlinks to important posts. I had forgotten CY was a key figure in these. Memories are fading anymore it seems!! Jeez!
Karl
bombelman08-07-2007 01:15 AMRe: Arc 4+ Switch?
Quote:
Thanks, Nick
Depends on which part of the switch you are talking about.
If you're talking about the part where the circuit is, I think you
are talking about the (snap) dome switch.
These are available and can be replaces...
Status
