Is there a beamdiffuser that fits the SureFire A2?
Does the FM34 Beam Diffuser fit? Or is there something else that works good as an beam diffuser. I know the low is floody, but I want a floody option for high too!
The FM34 is to big for the A2. It is for lights with a 1.25" bezel diameter.
It might be possible to shim it with some tubing or something, although it would be quite big and clunky on the A2.
AFAIK, Surefire did not produce a beam diffuser for the A2. Due to the fact that it has a unique bezel diameter (1.13") and has the LEDs for a lower output more diffuse light it was probably considered unnecessary.
Its to bad though, I tried the F04 lens over and I thought both high and low beam was quite nice diffused. maybe I´ll find something to make a diffuers with.
