p73rs
Hi. I feel the selector ring of my U2 is little too stiff as other people have said so here. So, I did search and found like this.
The selector ring is held onto the head with C-shaped metal piece at the back side.
There is an O-ring inside of the ring at the front side.
So, they put some lube at the frond side of the gap between the ring and the head, and it worked good.
I think I want to put some Nyogel there to lube it. It sounds simple, but the gap between the ring and the head is very narrow. The Nyogel is not liquid, either. Do I just smear the Nyogel around the gap and work out the ring to lube it? Then, the excess would be wiped off. I think I will warm up the light for better distribution of the lube, too.
Thanks.
Thanks.
