Which lights take remote switches?
mick53
Hi guys,
Does anyone have a list of the "less expensive" lights to which you apply a remote cable switch and where the switches are available? (There's one pictured below, this type of switch has a few different names, hence the pic).
I don't care if the switch is OEM or aftermarket as long as it fits the light.
Thanks,
Mike
rizky_p
13th Colony
i am pretty sure that Ultrafire C2 accept remote switch that meant to be used for Ultrafire 502.
Thanks
kosPap
Naoussa Greece
Thanks
well I do not thing there is a compatibility between the two...the 502B sxitch is a "male" type, tha C2 is a "female" type.
Regarding the latter...I like it...ALOT
its unique reflector gives a good spot, with a lot of spill, almost liek a "wall of light". I think it is a good choice for a longgun mounted light in one finds rings high enougn to compensate for the bigger head.
best luck, kostas
