eebowler
Hi guys. A few days ago, I was playing with my L2D and decided to do a roof bounce test. The flashlight was at medium level and when I put it down on the table to tailstand, it changed modes to low. It did slightly 'knock' the surface when I put it down so investigating, I realized that was the cause for the mode change. I repeated the results with a vertical drop onto the table of of about 1/2 to 3/4 inch. The mode change also occured from high to low but not from turbo to strobe.
I tried repeating the mode change by quickly tapping the switch with the flashlight on but it did not happen. It however did happen if I tapped the front of the light (resting it down face down,) and with a slightly greater force if I hit the side of the light against a table. I must stress that I'm not abusing the light, it's just a light tap which causes this mode change.
Have anyone else experienced this behavior? Can someone try to repeat these results with their own light?
The batteries in the light at the time were amondotech's enduro rechargeables.
Thanks.
Thanks.
