How is Adblock Plus related to Adblock? The development of Adblock pretty much stopped in 2004. When more and more people demanded improvements Michael McDonald came up with Adblock Plus 0.5 — basically a version of Adblock with whitelisting, filter subscriptions and several other useful features.
This version of Adblock Plus was still based on Adblock, which set hard limits to improvements. Quality of Adblock being… shall we say… less than adequate a complete rewrite was desperately needed. That came with Adblock Plus 0.6 — a completely new extension with focus on being easy to use, stable and secure. For various reasons many enhancements from Adblock Plus 0.5 didn't make it into the original release of Adblock Plus 0.6 but this changed with Adblock Plus 0.6.1.
Michael McDonald, the developer of Adblock Plus 0.5, has changed to the Adblock project and is trying to develop it further now. For that reason starting with Adblock Plus 0.6 the main developer of Adblock Plus is me (Wladimir Palant).
Need to know all the gory details? Check out
History of Adblock.
Do I need to install Filterset.G Updater?
No. Actually, it is recommended
not to use Filterset.G with Adblock Plus. There are several reasons for this:
- Filterset.G has been intentionally made incompatible with the built-in subscriptions feature in Adblock Plus, updating Filterset.G requires a separate extension which basically duplicates existing functionality.
- Filterset.G is not optimized for use with Adblock Plus, it will slow down your browsing considerably more than any other filter list.
- Filterset.G makes heavy use of very complicated regular expressions with the consequence that finding the source of problems is difficult and fixing those problems is even more so. In fact, Filterset.G is fixing most problems with exception rules which creates a problem on its own (see next point).
- Filterset.G contains a considerable number of exception rules. This is a big problem because exception rules cannot be overridden. It happened on several occasions that exception rules from Filterset.G whitelisted actual ads making these ads unblockable — something users usually blamed Adblock Plus for.
While Filterset.G has had its uses in the past, nowadays
other filter lists are certainly a better choice. If you already have Filterset.G Updater installed, you can uninstall the extension and remove the Filterset.G subscription in the Adblock Plus Preferences dialog. Feel free to choose any subscription from
the list then.
