Anyone know of any exotic coating or group buy currently open I am looking to coat my 2D mag to titanium or other harder surface.
HEY, I was right.....I LEARNED something....:twothumbs
Check Surface Solutions (www.tincoat.net) and Ionbond (ionbond.com). Done business with both of them. I do believe the former has a minimum order of $25 whereas the latter is $200 minimum. However, I also believe Ionbond offers a wider variety of coatings. Get a hold of them and ask away. Good luck.
jcompton, I think I recall seeing that table in modamag's thread.
Exactly, that's why I posted the chart, to give a visual of what platings can be used on Ti and which can be used on Al.I also recall he made the point that although a coating may be hard, it is very thin, so although it is a good protection against scratches, it cannot protect against knocks and dents. The Ti coatings are therefore likely to be better for Ti objects than for Al ones, as Ti is a harder metal to start with.
I have a Ti PD-S Mizer with the AlTiN and it is indeed darker, almost black, and definitely harder (according to modamag it is second only to the "C" aka "Diamond" plating).I have Ti lights with TiN and TiCN coatings. The TiN and TiCN will easily scratch just about anything else they come into contact with. TiCN is a blue-grey color, TiN is like brass (not shiny like gold). I believe AlTiN is even harder, and a darker color than TiCN.
Member erckgillis does all kinds of custom plating. I just spoke to him yesterday, and he can do one-offs of anything.
PM him, I'm sure he can help.
I would suggest you try to get a look at a TiN-coated light before you commit to it. It isn't really very shiny, and you can't polish it up as it is too hard. If you expect a finish like gold, you will be disappointed. Just my opinion FWIW.If I recall he is not setup for TiN or AltiN which I am interested in having done.
