Hi,
Anybody have experience on how to open up a Nuwai X1 ( 1AA) for
modding ( putting a SSC or Rebel emitter) ?
:naughty:
The Nuwai X1 is very similar to the Fenix L1 or L1P. It would respond well to a Seoul LED, and would require very little modification. The LED is accessed through the head, and the module is unscrewed with needle nose pliers, or similar tool.
Do some research on Seoul mods before you begin work, and you will find a lot of information about the emitter swap. If you like a floody light, it is a direct swap. If you want a more pronounced hotspot with improved spill, then you will need to use a 0.030" shim under the LED. You will also need to remove 0.030" from the back of the reflector.
Have fun!
