f22warzone
- Joined
- Nov 21, 2006
- Messages
- 32
ok this is my set up
WF-800 3W Cree Q2 LED Flashlight (2x18650 4xCR123A 7.4V~17V) Ultrafire 3.7V 2400mAh LC 18650 Protected Battery 2-Pack
now just last night when I was formatting my computer I decided I would do a run time test. And about 3 hours later the flashlight was still on I picked it up and it turned off. Strange hu. Well I shook it an ill bit and it turned back on then off again. So I thought it was just the batteries were dead so I put them in the charger. And put in my 2nd set of batteries but it was still doing the same thing then I loosed up the tail cap an ill bit and it worked just fine but as soon as I screwed the tail cap back in it would turn off. well I kept playing with it and then it got to the point where it wouldn't light up any more so I took apart the top and looked at the star emitter and every thing looked fine I test the batteries and some how the tail cap had shorted them out, their reading 1.3 volts apace :| so I put them in the charger but their so low on power the charger doesn't notice that their lithium's and thinks I am some idiot putting in nimh batteries in it but their just really low lithium's. Well any ways at the end I just took the ill plastic thing out with the brass looking pin so I just have a spring in the back now and its working fine with my second set of batteries not shoring out or nothing doing just fine. so I have 2 questions 1st how did the clicky short out the batteries when it just connects the batteries to the case witch makes the light up and if their was something wrong with the light why is it not doing it now. And the flash light never did get hot maybe 90-105'f and the batteries were cool to the touch also. And my 2nd question is their any way I can revive my batteries or at least get them up to about 2volts so the batteries charger recognizes them? Or is it a problem that maybe the PCB is tripped and that it's not letting them charge just drain? And if so is their any way I can fix this or should I get a refund for them
