Yes it is fine to put 3V directly to the LED, the normal driving voltage of the LED is around 3 1/2 volts so it won't be a problem to test the LED that way. Some lights are even direct-driven without a circuit using a 3.7V lithium or 3x 1.5V cells. 3 volts is enough to test if the LED is working or not though.
