Klarus
Page 1 of 2 12 LastLast
Results 1 to 30 of 44
Thread: Experiment: can an aspherical lense be substituted with a Fresnel lense?
    Flashaholic* Nereus's Avatar
    Mar 2005
    Espoo, Finland, Northern Europe
    Talking Experiment: can an aspherical lense be substituted with a Fresnel lense?
    I finished my aspherical Mag (see this thread) some time ago and I have been very satisfied with it. However, there is one weakness in it, the protruding glass lense which is very fragile:
    In principle aspherical lense can be substituted with a flat fresnel lense and of course I had to try that...
    I found a suitable fresnel lense in the Rolyn Optics catalog, namely this product. Here you can see a photo of it:
    The diameter of the actual lense is some 5 cm so it is perfect for a D size mag. Focal length is 32 mm. Here I hold the lense in my hand for a size reference:
    It is indeed perfectly flat:
    Next I had to cut the square edges away, otherways it will not fit in the Mag head. Intact lense on the left, cut-down on the right (yes, I bought two of them... ):
    Here is a closer look on the cut-down lense. Acryl is surprisingly hard and brittle. That's why the edges are quite rough but you can't see them after the installation.
    Here you can see the fresnel lense installed - perfectly flat lense guarded by the bezel
    Glo-powder glows through the fresnel...
    Here is a close distance beamshot with as narrow beam as possible:
    The beam at its widest (you can see my kitchen ceiling here... ):
    The beam projected by fresnel lense is very similar to the beam projected by aspherical lense - based on the beam profile, you can not tell which optics is used.
    So far this fresnel lense experiment has been a success story - all the benefits of an aspherical lense without its vulnerability. However... when I measured center beam brightness (narrow beam) I noticed that aspherical lense performs slightly better: 57 600 lux @ 1m for aspherical and 40 000 lux @ 1m for the fresnel lense.
    So, to answer my own question in the topic of this thread: yes, the aspherical lense can be substituted with a fresnel lense but there is a trade-off here between robustness and performance of the flashlight.
    On the other hand this was my first fresnel lense experiment and the performance might be improved with slight changes in the fresnel lense specs. I guess I have to order a few more...
    Thanks for looking!
    -N
    My mods. Please post questions about my mods to the corresponding thread: like that all CPFers can get the info - thanks!
    Flashaholic* f22shift's Avatar
    Jun 2007
    Singapore, NY,SH,BJ
    Default Re: Experiment: can an aspherical lense be substituted with a Fresnel lense?
    great find!
    Flashaholic* datiLED's Avatar
    Atlanta, GA
    Nereus,
    That is a very cool experiment. I like the way you think!
    Be still, and know that I am God; I will be exalted among the nations, I will be exalted in the earth!
    Psalms 46:10
    Flashaholic* TorchBoy's Avatar
    Jan 2007
    New Zealand
    No, a torch does not always mean flames.
    Ian.
    LED Driver List - now database driven and with new search features.
    Super Moderator
    DM51's Avatar
    Oct 2006
    Borg cube #51
    It is an excellent solution to the problem of the bulky aspheric lens, and it will reduce weight, but a fresnel lens is never going to be as good optically as a true optic, because of all the refraction rings. With each ring you get a slight drop in optical efficiency due to slight scattering at the ring margins.
    Resistance is futile...
    Flashaholic* stitch_paradox's Avatar
    Sep 2007
    S.D.CA
    Buttrock Re: Experiment: can an aspherical lense be substituted with a Fresnel lense?
    great experiment!
    Flashaholic* PhantomPhoton's Avatar
    Jan 2007
    NV
    Nice idea.
    Aside from the enlightening input that DM51 gave, also theres ~ a 5 mm difference in focal length between the Aspheric and the Frensel. (I saw someone put up the math here on CPF once but I have since forgot) I s this going to have a significnat impact on lux as well? I don't think 5mm is going to account for over 17000 lux but it probably counts for part if it.
    Mmmm Frensel Mag. Must have one!
    (Beautiful Green Mag there by the way )
    1) Neutral white, it's the new black. Heck, it's not even "new" anymore.
    2) User Interface... KISS.
    3) Proprietary cells and battery packs - Just say NO!
    Super Moderator
    DM51's Avatar
    Oct 2006
    Borg cube #51
    The focal length will dictate the correct distance from the lens to the emitter, if the objective is to produce a perfectly collimated (i.e. almost parallel) beam. A shorter focal length lens would be placed nearer the emitter than one with a long focal length.
    Given lenses of the same physical diameter, the angle from the emitter to the lens would be smaller in a longer focal length lens, which would therefore collect a smaller proportion of the light emitted.
    However lenses of a longer focal length are likely to be more accurate and more tolerant of emitter characteristics, so there is no hard and fast rule about the optimal diameter / focal length ratio.
    The ideal would be a large-diameter lens with a proportionately long focal length. I think Long_John made something with a large lens like that, and the result was pretty impressive IIRC, but in the lights we are discussing here, the diameter and focal length are governed by the size of the host (Maglite) bezel.
    These considerations are the same for fresnel and true optical lenses.
    Jun 2007
    Singapore, NY,SH,BJ
    the acryl is a plexiglass type material? but you mentioned brittle so is it like glass? what did you use to cut it?maybe you can sand the edges?
    where did you buy it? link?
    this could be a good alternative to someone who bangs up their flashlights in daily use.
    Flashaholic jashhash's Avatar
    Sep 2004
    Phillips Ranch
    Im not sure if you could find this, but wouldnt a glass lense be much better than accrylic since it's more transparent. Great experiment.
    "And these three remain: faith, hope, and love. The greatest of these is love."
    Love /verb/: Giving what is needed to those who need it because you care
    Flashaholic* lctorana's Avatar
    Jun 2007
    Melbourne, Australia
    Help Re: Experiment: can an aspherical lense be substituted with a Fresnel lense?
    Excuse my ignorance - AGAIN...
    Is there such a thing as a glass Fresnel lens?
    Flashaholic* Aircraft800's Avatar
    Apr 2007
    DFW Texas.
    Nice Find!
    *Flashaholic*
    Apr 2004
    Lost In Space
    He Did it
    i was hoping somone would, i really needed to know if that was possible very interesting results
    which leads to stupid question #1, now could this be done Removable?
    flip in, snap in, swing in, and then what could you have as "normal" behind there.
    question #3
    this is ~5mm FURTHER away from the led right?
    because Nereus has his heat sinc hotlips or whatever shoved down pretty far, i still have the lip on mine, and its a beech to move, so it sits up about 3mm further.
    How many "threads" or turns are left to your head falling off, or going past the o-ring
    then reverse that, nereus (and others) also have some space removed from the mags Head threads, which puts the aspherical down closer to the led.
    some Others from what i saw are still applying cam rotation ( of reflector) for led drop-in movment, i have not seen one of those in person or pictures yet to completly understand it.
    question #2, is the actual focus of the projection harder to "maintain" at different distances.
    the oversized freznel that i played with here unsucessfully, has to be moved (focused) to a different position if i hit the wall at 8 feet, or if i hit the tree 200 yards away.
    the asperical lens thing (basically) stays a tight beam near or far, does this frenel lens work the same for focus as the aspherical, not the zoom aspect, but actual focused projection of the led die?
    i will get to questions 4-100 later :-) this is really interesting.
    Super Moderator
    DM51's Avatar
    Oct 2006
    Borg cube #51
    Quote Originally Posted by lctorana View Post
    Schott make glass ones, and I'm sure there will be other manufacturers too. Glass would be needed where very lot bulbs are used.
    Mar 2005
    Thanks for the positive feedback - wow! I guess it's time to answer the questions...
    DM51: Yes, the optical "imperfectness" (is that a word?) of the fresnel lense might be the explanation to the weaker performance when compared to a true optic.
    PhantomPhoton: Even though the focal length is 5mm less in the fresnel lense, it seems that it has to be set *further* away from led... weird? I guess that when you couple this to the comment of DM51, you get the explanation for the center beam brightness difference.
    f22shift: The material is harder than regular plexiglass but softer than pure glass. When I cut it with pincers it fragmented in small sharp chips.
    jashhash & Ictorana: I guess DM51 answered your questions. And yes, glass might be better material for fresnel lense.
    Vidpro: Thanks... About the 5mm difference in the focal lenght, see my answer to PhantomPhoton above. I think this is reversible mod because you can remove the fresnel lense and the led+heatsink combo. And with the fresnel lense, you do not need to remove material from the flashlight head. The need to re-focus at different distances is similar with fresnel and aspherical lense. Waiting for your questions 4-100...
    Ok, next a few more further considerations... It is good to put the brightness (lux @ 1m) difference in perspective (literally?): the ability to throw does not depend linearily on the brightness. In order to double the throw in metres, you have to multiply the brightness by four. This means that there is square root relationship between the brightness and throw (See this PDF file for further info). Let's put the numbers in:
    (57600-40000)/40000=0,44. So aspherical lense has 44% greater brightness than fresnel lense.
    sqrt(57600/40000)=1,2. In other words aspherical lense can throw 20% further than fresnel lense. The difference here is smaller than the difference in brightness.
    One more comment that I forgot to mention in the first post: the fresnel lense has to be installed grooves facing out. And you have to install a UCL lense in front of the fresnel lense in order to prevent it from rattling and in order to protect the fragile grooves. So there are two flat lenses "sandwiched", UCL being the outer one.
    BTW guys, I still haven't decided if I prefer aspherical or fresnel lense. Max throw or robustness, that's the problem!
    -N
    *Flashaholic*
    Apr 2004
    Lost In Space
    Q#4 , are all fresnel lenses basically made with a similar focal point?
    (like how did you figure out which one to get)
    #5 could this be done small too
    #6 is there fresnel magnifyers for just normal magnifying stuff that arent so nastily ridged? i want a pocket magnifyer but i find that viewing through (the cheap stuff) is not anywhere near as good as a normal magnifyer.
    #7 the point focus is not as bright, but did you lose "overall lumens", or are those lost lumens spilling all about the place as usual.
    Mar 2005
    Quote Originally Posted by VidPro View Post
    Q#4 , are all fresnel lenses basically made with a similar focal point? (like how did you figure out which one to get).
    There is lot of variability in the focal lengths (and other specs) of fresnel lenses, just like in that of aspherical lenses, see e.g. this Rolyn Optics catalog page. I found my own fresnel lense simply by searching the one having the specs closest to the specs of the original aspherical lense (52mm diameter and 37mm focal length).
    Yes, it can - you can find examples of small fresnel lenses on the page quoted above.
    It's inherent that fresnel lenses are ridged (or grooved). Of course you can increase the density of grooves which makes the grooved surface look more smooth.
    Hard to say - I do not have integrating sphere with which I could measure the total lumens. But like said, the beams are very similar when comparing fresnel and aspherical lense. So I guess that there is not very much difference in lumens.
    -N
    Oct 2002
    Baden.at
    Default
    nice one!
    except for the part that the grooves have to be mounted to the outside + front glass.
    What happens if they (or the aspheric) are mounted the other way?
    Shouldn't it work the same?
    *Flashaholic*
    Apr 2004
    Lost In Space
    Quote Originally Posted by yellow View Post
    nice one!
    i have mounted an asperical reversed and it "worked" then i punched it into a cree dome and destroyed the dome :-) oops, i almost had it.
    Oct 2002
    Baden.at
    Default
    doh,
    didnt think about this.
    Sure the dome will now point inside where there is not enough space
    Sure! Fresnel invented his lens for use in lighthouses long before the era of plastic
    http://www.lighthouseratings.com/Lens/
    Jun 2007
    Ahhh
    yes, of course. I can picture that.
    An optical version of a horn.
    Flashaholic* LukeA's Avatar
    Jun 2007
    near Pittsburgh
    Quote Originally Posted by Nereus View Post
    The focal length of the lens is measured (if I'm not mistaken) from the focus of the parabola that is the non-flat part of the lens. This focal point is (should be, I think) several mm inside the lens. The focal point of the fresnel lens is very near the lens's surface, so even though the lens has a shorter focal length, the focal length is measured from nearer the outside of the lens.
    A little madness never hurt anybody.
    *Flashaholic*
    Apr 2004
    Lost In Space
    hmmm
    from: http://www.anchoroptics.com/catalog/product.cfm?id=402
    High groove density allows higher quality images, while low groove density yields better efficiency (as needed in light gathering applications). In infinite conjuate systems, the grooved side of the lens should face the longer conjugate.
    i was trying to find a very clean magnifyer (high density), like what is on film cameras $$$ and learned that. might be usefull?
    that could be why the stuff on lights like marine lights and all, is HUGE grooves.
    and Because the lens is thin, very little light is lost by absorption.
    from: http://www.anchoroptics.com/catalog/product.cfm?id=404
    which might indicate that thinner is better?
    Mar 2005
    nice one!
    I tried installing the fresnel lense grooves facing in and the results were poor. The led die was projected like before but lot of lumens were lost.
    -N
    Mar 2005
    Quote Originally Posted by LukeA View Post
    Ah, that explains my findings - thanks LukeA!
    -N
    Hi there
    great use of the fresnel lens instead of an aspherical. I had a quick question about the mod.
    You mentioned ( in the original thread, with the aspherical lens) that the hotspot was about 5 cm from a distance of 1m, and this is similar in the fresnel lens. What happens as you increase the distance? have you looked to see how wide the spot gets at, say, 5 metres? and how easy would it be to re-focus the spot for this distance? is it a matter of moving the lens a little further away?
    Im looking at a P7 mod, and was hoping to use a fresnel lens to get a roughly 15-20 cm tight spot from around 5 metres or so. Not so interested in throw ( at least not the 100's of feet seen in this forum) itself, but the lumens have to be tight for my application.
    thanks in advance!
    Wow great thread!!!
    Thanks for bumping this one up, otherwise I would have missed it.
    Great information!
    Flashaholic Nos's Avatar
    Dec 2007
    Germany
    ive tried a 500x500 mm overhead projector lens........but the results were disappointing
    same with a brandnew biconvex 120mm glas lens, it did only throw ~10% more than the KD lens but with a much smaller die
    -----> i guess the reflections from the backside caused the loss of light, because i nearly got blinded by it
    after testing every type of lenses in my oppinion its most important that the lens is made of optical glass and plano convex. and furthermore i think that a AR coating is more important than the aspheric form.....
    proud Fenix T1 aspheric R2 owner
