hmmwv
Last night (this morning??) I offered to post some photos of a comparison between NICD charging circuits and NIMH circuits.
The nicd circuit is inside the 9N charging base and can be seen at
www.hmmwv.net/charge.jpg
the components ( from left to right ) are the idiot diode (for the idiot who connects the polarity wrong) - the voltage regulator - the power resistor to make it look like a constant current source, and two resistors/leds to tell you it's working. Pretty simple. No rocket science here. No rocket science funding either.
Now take a look at the NIMH counterpart.
www.hmmwv.net/c2.jpg
this is an evaluation board by benchmarq that handles nimh chemisitry and treats it with respect. As you might expect, it is substantially higher in cost to manufacture than the simple constant current nicd charger used in the 9N charger. The spec sheet alone for the BQ2004E chip is larger than the surefire catalog.
Trust me - switching to nimh chemistry batteries is a pain. it's your pain threshold that determines if you're going to do it or not.
BTW - tonight the 3000 mah pack after resting, charging overnight, and starting again today ran bright for 75 minutes, then suddenly (i.e. 30 seconds or less) went to nothing. This was cycle #2 for prototype #1. Cycle 3 should increase even more.
This *IS* a learning experience.
