Does anyone EDC a multi-LED light?
TigerhawkT3
CA, 94087
When I say "multi-LED," I mean Trilux or more, not a 5mm showerhead. When I say "EDC," I mean every single day carry, not "EDC when I go on night hikes," because that really isn't EDC.
So, does anyone EDC one, or are they all still too bulky?
LEDcandle
Mushroom S'pore
If anyone EDCs a C2 or M3 or U2 or A2, then it would be the same as someone who EDCed a tri-lux built into those form factors. I believe there are folks who EDC this size of light.
Personally, 1xAA is the biggest I go.
When modamag finally decides to reply and send my drake out, I might just EDC that only; let's see :)
paulr
There's a new board with three Luxeon Rebels in a very tight cluster, that will probably make edc lights with multiple high power leds a reality. I suppose you could also count the Luxeon V, which was really four leds in a single package.
First thing I thought of when I saw the title of this thread was my 1aaa, 3x5mm Peak Matterhorn, but that's clearly not what you had in mind.
270winchester
down the road from Pleasure Point.
do you have a link to a tri-lux light in C2 or A2 size?
I remember someone from Europe made a tri-SSC in a KL4 head. pure flood, but looks very usable.
LEDcandle
Mushroom S'pore
Erm well, I meant more like Milky's mods into the KL heads running a stock body or some other 2xCR123a or 18650 body... I guess tri-led will be a tight fit for the stock SF heads but I'm not sure if it's been done before?
If we do it mule style (just the emitters without reflectors), I believe a tri-LED in a stock SF head would be no problem :)
LEDninja
Hamilton Canada
Anyone notice most of the current crop of AA lights are much bigger than those of 2 years ago. The Civictor V1 is the biggest that will fit into my jeans' pocket comfortably.
I am down to EDCing AAA lights. I only get out My Little Friends (3x3W or 3xSSC-P4) when I know I need light.
LEDcandle
Mushroom S'pore
I EDC a pouch even when in business shirt/pants (yeah, geeky, who cares...haha) so the length is just nice ;D
On casual days I'm in cargoes, so no problems either.
I guess for typical jeans, they might be a bit big!
Illum
Central Florida, USA
I carry the A2 and L4.....
A2 [not a trilux....but not a showerhead either]
L4 [not a trilux.....but equivalent of carrying 4 luxeon Is, does that count?]
I don't know of any quality multi luxeon lights [save nuwai] that comes budget....most stuff coming out of the custom section are way more than most of us can afford
EDIT: come to think of it.....elecktrolumens lights aren't bad and aren't too expensive either....aside from the many to choose from....I still look in awe of the ELX-12D
TigerhawkT3
CA, 94087
So, nothing really compact? I'd like a right-angle light like the SL Survivor, but with two C or D Li-Ions side-by-side and the head with emitters and reflectors on top of it, with a short clip behind the head, all forming a basically box-shaped unit. Give it a good heatsink and two or three well-spaced levels, and that'd be good times.
Avatar28
Nashville, TN
Well my EDC is now a P3D but previously it was a Dorcy Super 1 Watt with a single Luxeon. I only bring that up because our children were gifted a cheap 9 LED array light that would easily fit into a pocket. It uses 3xAAA cells in a holder and is probably no more than an inch across and 4 inches long. I was surprised at how much light it gave out, probably comparable to the Dorcy and with what appeared to be a better overall runtime. They boys took them on a caving trip and it was a good probably three hours into the trip before I had to swap out the batteries due to them getting noticably dimmer. The build quality is so/so, they do feel pretty light and appear to be made of Al; the threads are really rough screwing the tailcaps on and of and they are probably no more than splash resistant, I don't think I would try dunking them. The LEDs are a mixed bag. One of them has a definite bluish tint to the LEDs but the other one is a pretty nice white, whiter than he Luxeon on my Apex for instance. Like most close arrays they give a very even floody light with a diffuse spot. I know you said no showerhead, but considering the compact size I don't believe these should qualify as such. I don't think they cost more than $10 either so +1 for price there. I don't really EDC one but I think it would make a decent EDC light for a non-flashaholic.
mcmc
I used to EDC a Little Friend, in a leather holster made by Kazu. It wasn't too bad actually, having it on my belt, and didn't show much from the outside either. The runtime was a bit low so a bit of a hassle, but outdoors at night, wow.
LEDninja
Hamilton Canada
I have a pouch for My Little Friendthat looks the same as the one for my cell phone so it does not look out of place. Unfortunately Elektrolumens builds his lights like a tank and they weigh like a tank. Which is why I do not normally carry it.
The Little Friend is no longer in Production. Elektrolumens is now selling the FireLion (1x18650) which is probably the shortest multi-power LED today. All the others I came across seem to be 2x18650, 4(or more)xCR123A.
