thermal guy
I see all the run times for novatac on high settings but has anybody seen one at the realy low settings? say level 1 or 2. they must be alot longer than the old hds.
I believe somewhere here there is a runtime test of an HDS flashlight on lowest which ended after 45 days. So these calculations are not far from reality.Howdy thermal guy,
Page 13 of the NovaTac instruction manual shows the runtime at level 5 (.33 lumens) as 240 hours. I believe that as the light output is cut in half, the run time is supposed to double...... and using that as a basis, when the light output drops 2 levels to 0.17 lumens, it should get 480 hours, and when it drops the final to levels to level 1 (.08 lumens), it should, theoretically, get 960 hours of continuous runtime.
960 hours, divided by 24 hours in a day, comes out to 40 days.
