plasmaman
OK - lumens.
I got a cheapo (but well recommended) luxmeter.
People ask - how many lumens??/
I don't think its that easy!!
Conclusion is that its OK to measure relatively, but not objectively.
Here are some shots of a test I did tonight, as controlled as I could easily devise.
Box to hold the meter sensor with aperture to fire the lighjt through at the same distance each time. Camera set to auto exp. Camera on tripod, remote shutter release, pressed when I thought I had the highest reading on the meter (not easy as it fluctuates with the slightest movement)
Meter set to 100x lux.All lights run from standing cells, not recharged for this test.
Then my second problem. If I see 1000 lux on the meter at 100x scale, that means 100,000 lux - WOW!
But the meter measures up to 50,000 lux - duh?
Here are the pics - lots....The last pic shows the box set up most clearly.
2Li C, AW switch, 5761 bulb
9 NiMh 1164
2 x (4x14500) ROP HI
2 Li C Tri Seoul P4
4x14670 Nflex quad P4
1 L1 D ubercell Seoul P4
3x17670 1185
Mac proto 3 x 17650 Seoul
Mac aspheric 1C
uberLi D tri P4
uber Li D P4
7x NiMh 64250
SF M6 6x rc1231185
UF 500 2x18650 1111
uber Li D Q5
uber Li D Q5
9 NiMh 1164
2 Li C Tri Seoul P4
3x17670 1185
Mac aspheric 1C
uberLi D tri P4
uber Li D P4
7x NiMh 64250
SF M6 6x rc1231185
UF 500 2x18650 1111
uber Li D Q5
uber Li D Q5
