ViReN
So... What du ya think?
my perfect edc would be the L2D 100 with a variable twist head from 0-100 ,
I like this idea, there is a serious lack of small, quality 18650 lights on the market. My only objection is that, like with the LP MRV and other many-batteried lights, the regulation on 18650 suffers badly to accommodate RCR123a cells. Even the Tiablo A8, simply by only offering CR123a compatibility (which makes sense, considering most people don't have RCR123as) has a much better regulation curve than the MRV does. The Tiablo A9 supports RCR123as and the regulation curve looks more like the MRV. If Fenix were to go through the trouble of making an 18650 light, I would ask that they optimize it for that battery ONLY (but hey, once you get a good Li-Ion regulation circuit you can use it for many different cell sizes, hint hint), and that they make it available with a twisty (like the P1D-CE) as well as a clicky interface for those who want to EDC the light but don't want to take up extra pocket space with a tailcap. Oh yes, and don't depend on the cell's built-in low-voltage protection to kick in, please set it to turn off when Vbat (under load) reaches somewhere around 2.9V-3.0V range.Probably not worth it to Fenix, but for geeks: Build a 18650 based LOD-CE type light, as small as possible to fit a protected 18650. Allow it to also run on 2xCR123/RCR123. Thread the head so it will also fit the P3D body with clicky if possible (may not be).
More not worth it to Fenix, but fun for geeks: build a L2D-CE in 2xC size. Use wider diameter reflector to create a brighter hot spot. Design it to run flat with alkies like the E1.
huh... my avatar is active?.... where do you see it? ... I had removed it long back since last run of Copper Heat Sinks for Nuwai QIII.....
