Blindasabat
I have a special request for a P60 drop-in:
It is a simple two mode that switches between full high and a 25-50 Lumen low with a Quick tap. It remembers what level you used last. The quick tap is less than a tenth of a second. I think this is similar to the Aviatrix A2 LED drop in. My reason to have this, besides the obvious "longer run time" and "150L is often too much light" reasons that make me not use my G2 with 150L drop-in very often is the concern that running full-on high 150L for a long time will heat up the LED module too much in the plastic bodied G2.
