Lesson Learned: Checking Blown Fuses...
turkdc
Shelby Township, Michigan, USA
My X-Ray machine took a dump on me last night. Wouldn't turn on, kablooey. Figured I would save myself the $150. service call and see if I could figure the problem out myself. I removed the cover and began by checking all of the fuses with my Ohmmeter. Everything checked out ok. Since I am a chiropractor and not an electrician, I decided that any further probing was best left to the technician.
Tech came out this morning. Checked the fuses. One was blown.
I made the mistake of checking the fuses still plugged into their circuit. The continuity I was reading with my meter wasn't the fuse, but rather the rest of the circuit.
This was a costly lesson for me. Hopefully someone here can learn from it. I'm an idiot.
:thinking:
MarNav1
Nebraska
Your not an idiot. Like you said you aren't an electrician. Next time you will know how to check them.
Sigman
* The Arctic Moderator *
"The 49th State"
Agreed, you're not an idiot...chalk it up to lesson learned & "that" won't happen again!! NOW, if you do it again - we'll have to have a talk! :D
Burgess
USA
I once encountered a standard-type glass fuse,
one-quarter inch diameter, by one-and-a-quarter inch long.
Removed it from the fuse-holder, and gave it
a VERY CLOSE, visual inspection.
It looked fine. Could see absolutely NOTHING wrong, even under good light.
After an hour of tearing my hair out, :hairpull:
i once again decided to inspect the fuse.
"it's GOTTA' be the fuse !"
"it CAN'T be the fuse !"
Only, THIS TIME, i used my handy Simpson 260-7P multi-meter.
Sure enough, that fuse had blown !
But i defy anyone to spot it, with their eyeballs.
Felt like an idiot. But i've always remembered it.
:stupid: ___ :banghead:
Just a word to the wise. :ohgeez:
_
Diesel_Bomber
It looked fine. Could see absolutely NOTHING wrong, even under good light......
Yep, done that too! Probably 18-20 years ago(I'm 28), but I still remember it well.
This should have gone in the "Things I've Learned The Hard Way" thread.
:buddies:
The_LED_Museum
*Retired*
Federal Way WA. USA
I've made that mistake too.
And when I was much younger (early teens), that mistake resulted in the destruction of a perfectly good analogue meter.
Mistake 1: Leaving the fuse connected.
Mistake 2: Leaving the device itself plugged into a live 115 volts AC circuit.
I actually saw the magic smoke escape from the meter movement; apparently, the internal resistance of the battery was insufficient to protect the coil of the meter movement.
